The rubber bushing is part of the prop, it's in the middle or hub or the prop. Many times it's cheaper to just to get another prop.
That motor is a twin, 2 cylinders- 2 plugs.
The 9.9hp models does not incorporte a shear (drive) pin. It has a splined propshaft that locks onto a splined thru hub propeller.
The propeller is a 3 piece unit..... bronze hub and a standard aluminum propeller, with the propeller attached to the bronze hub with vaulcanized rubber. If the rubber fails, this allows the bronze hub to spin within the propeller.
A long shaft engine cannot function properly when installed on a short shaft transom. The extra engine length creates its own drag and if it is possible to obtain any kind of speed, a rooster tail is usually and normally a unsightly result.
Now.... DO NOT ever open up the throttle (if possible) on a engine while in neutral unless you want to chance a runaway engine and have connecting rods go flying thru the side of the crankcase.
In gear (the problem)...... Does the engine rpms increase to the normal full throttle rpms while the boat slows down? Does the engine rpms NOT increase to the normal full throttle rpms when you open the throttle. We need a detailed explanation of what exactly is taking place.
Hi Bob from your quote, "like make a mark across the prop and inside hub and then go run the motor , and come back and check to see if the marks are still lined up with each other"your prop will not cost you $277!!!!!!!!!!!!!
ask at any marina your prop in aluminum will be $95 max....
and if you shop around maybe even $50..
you cannot fix your old prop yourself , if the hub is spun..and it probably is..i bought a 1990 15 hp which uses the same exact prop and is almost the same motor and the prop was spun as well on my motor!!!
I picked up a used prop at a local shop used for $15!!!
do not try to buy hub parts...you will end up looking at a compnent system used for larger motors.
i am not sure, but I dont think they make interhcangable hubs and props for your size motor!!!
they do for motors who need $277-$500 props!! ha ha ha
did you even do any of the suggestions offered yet??
like make a mark across the prop and inside hub and then go run the motor , and come back and check to see if the marks are still lined up with each other????
on my spun prop, i could easily see bit of rubber torn up along the out dia of the rubber where it meets the metal.
PS you are mixing up teminology..hubs and bushings are SIMILAR things, but the same things!!!
you can't use a new hub and fix it yourself, and you probably dont need new bushings...
good luck
bob
Sounds like you aren't firing on both or a fuel delivery problem, when this happens they fall on their face. This is typical of an ignition problem, will rev no problem in neutral but won't under load.
he cant be firing on only one cylinder!!!!!
the motor would never run on one cylinder?? would it?
he may have weak spark....but not firing at all??
the motor isnt powerful enough to push itself over on only one cylinder.
( i wouldnt think)..maybe a 30 hp -50 hp twin cylinder motor to run on one cylinder, but a 9.9??
bob
bob
In fact, they run smooth as silk on one cylinder. They even almost get you up to plane and will troll all day one one cylinder. They just lack good snap and top end speed on one cylinder. Rick.
