I have the same setup I just changed the impeller and that is a pee hole in the housing. I did have a bad impeller and when I changed the gasket and oring it did not leak anywhere but from the pee hole. It does show it in the manual I started mine on muffs with the cover off and it shoots water out of the pee hole about 20ft. nothing hooks up to it it is right....
