hopefully correct link and sync
KT64TM
Baseline:
WOT @ 40 degrees BTDC :O
Initial pickup-----??? the collar had shifted
NOW:
WOT @ 25 degrees BTDC
Initial pickup at 4 degrees BTDC
Havent had the chance to put it in the water yet for the rest.
Do my #'s sound right to you gurus??
KT64TM
Re: hopefully correct link and sync
Haha that would help
72 merc 800
initially I tried using the post in the FAQ but found it confusing. So out came the mercury manual. (pictures)
The trigger collar had spun.
First thing I did was set the dissy to 23 btdc and set the advance screw. Then adjusted back to 4 btdc
Then adjusted the trigger collar so that it was just touching the carb cluster
then adjusted wot screw per manual
haven't had it in the water yet.
Advanced timing to 4 NTSC then adjusted trigger collar to just touching the carb cluster.
Laddies
Banned
You have got it right have a good ride.
KT64TM
Phew thanks!!
I'm amazed that the timing was at 40 btdc and it was even running.
