need a diagram
fishingman220
i need something to tell me exactly how to put all the accesories back on the front of the motor, i took pictures but now apparently not good enough. it is a 96 mercruiser 2bbl.
dr_bowtie
Re: need a diagram
blow the picture up so you can see better...:)
fishingman220
Re: need a diagram
yeah i tried, i didnt take it from the right angle, i cant see where spacers go and what uses the same bolt holes, i got it together and i think i have some bolts in the wrong places and i have a spacer left over and dont know where it goes. just wondering if there is a diagram of how it all goes together
gshldon
Re: need a diagram
Did you check in the manual for your specific engine in the sticky section?
fishingman220
Re: need a diagram
yes i have downloaded the manual and there arent really any good pics of it in there
John_S
Re: need a diagram
There was a bunch of changes through this period. I have a '96 1/2 which has the serpentine belt. Early '96 had seperate belts. If the former, I have a bunch of pictures of mine that may help. Let me know, and will post them.
mkast
Re: need a diagram
Look in the parts manual for assembly.
fishingman220
Re: need a diagram
mine uses a v belt, 2 one for crank, water, powersteering, and one for crank, water, alternator, where is the parts book?
jtybt
Re: need a diagram
Basically, you just have to make sure the pulleys line up. The washer left over probably is letting a pulley out of alignment.
