Sup-r-lube bearing hubs ( bearing buddy types)
kellerqx
I have a 1996 trailer & boat with sup-r-lube bearing / greasing device, looks like a bearing buddy. This weekend I put grease in them ( first time since I purchased in Dec ), after about +2 ozs. the old grease started to come out the front. I was kinda greenish/whiteish looking, possilby some water mixed in is my guess. Is this correct or did I overfill and possibly damage them, or should I continue to fill until the new color grease comes out too? Should the grease go thru and out the back of the hub? Please advise. I plan to go on a 6 hour trip and dont need to be on the side of the road with a locked up hub.
Rocky_Road
Re: Sup-r-lube bearing hubs ( bearing buddy types)
If there was a zerk fitting in the center of the axle spindle...then you are doing just fine! That is the correct method to fill (and refresh) the bearings. I use a plastic bag to keep it fairly clean.
I suggest that you continue filling until you see the color of the grease that you are adding. Then 'scoop' out a small amount, for expansion room as the bearings get warm.
kellerqx
Thanks, thats exactly what I'm seeing. Guess I will buy some more grease and continue to fill them up until the new color begins to flow.
lmannyr
Don't you blow out the rear seal by doing it this way? I have the same setup up and had to replace 4 spindles, bearings, seals, after 9 months of use because it slung grease and water rusted the spindle seal surface, and where the bearing rest on spindle.
drstressor
Super Lube hubs don't have a pressure plate like Bearing Buddies do. You can't blow out the inner seal since they don't operate under pressure.
lmannyr
What is a pressure plate?
On my setup, it's Double lip inner seal, inner bearing, outer bearing, washer, nut, then retainer.
Rocky_Road
Here is the path of the grease:
