longstand
Thread starter- Joined
- May 2, 2009
- 293
I have been searching for this topic but they have answer for there problem..
but my is a little bit different..
I been trying to lower my outdrive and raise up
all it does it click click .
so i have remove the motor from the Socket and test it.. the motor Spin, it seems to be working very good..
but when i put it back into the housing. it does the same thing.. iam no expert but if the motor is not good it will not spin in any direction at all.
but when i try to lower the outdrive or raise it i could keep clicking . and few minutes and a few hundred click later it will be down..
i have remove the Tilt Machinism and clean all the old oil and replace with new OIL...
Also i have a twin engine. so the other Trim is doing the same thing.. its weird.. how can both Trim have the exact problem.. it was just working .. well it was barelly working. and when i did some maitainace on the engine it did this??
ANy IDea
ANy IDea
