SeaVue
Thread starter- Joined
- Mar 14, 2009
- 76
Re: 888 mercruiser won't start...
UPDATE:
OK, i put the spark plugs back in and tried to turn the motor on but it didn't work. The engine turns and turns but it doesn't do it at constant power. What i mean is that the pulley with the bolt will make a few good rotations and then it will stop. As if something is preventing it from turning with ease.
It seems when the pistons or cylinders (not sure which) gets to the top of the cycle it has a hard time doing it. I assume this because with the spark plugs in the motor, i try to turn the engine manually and it works, but after getting close to a full rotation it gets much harder to turn the pulley.
When i take the plugs out and turn the key the pulley turns without any problems. When i checked the plugs they did have a little oil on the them. (from the oil that i put in earlier).
I kept turning the key to 'pump' out the water with the spark plugs out. Nothing seems to be coming out of the holes anymore. I did notice that my battery is loosing power. I am going to charge my battery and going to try it again this afternoon or tomorrow. Ill keep you guys updated. Please help.
Thank you.
UPDATE:
Thank you.
