SeaVue
Thread starter- Joined
- Mar 14, 2009
- 76
Re: 888 mercruiser won't start...
ErieRon,
How do i check if my rings are worn?
Basically what happens when i try to turn on the engine is as follows: the engine cranks normally (full of life) as if it would turn over, but it doesn't. What I'm trying to say is everything sounds good, as if the engine would start but it just doesn't.
Matt 57,
the engine did not get hydro locked at high RPM's. I'll read up on the Marvel Mystery Oil and thanks for the heads up on the spark plugs. Might give it a try (burning the tips); nothing to loose.
bruceb58,
are you sure that i should still be able to get the engine started with the compression numbers that i have?
I was doing some research and i found this:
"If the timing belt or timing chain fails it will cause the camshaft to become out of correlation with the crankshaft or allow the camshaft to stop rotating. Either of these conditions will cause the engine to lose compression and sometimes cause internal engine damage." Website
Since i did turn the engine manually using the socket, could i have done something to the timing belt?
ErieRon,
Matt 57,
bruceb58,
