Whaler Rage VRO problems
Dataphat
Vro pump is putting out way too much oil smokes and wont run.
Thick oil comming out of drain on carb bowls.
Is it ok to premix 50:1 and disconnect oil hose and alarm?
Its old prob. orignial pump.
How much are they new any way (VRO)?
ty,
kenmyfam
Re: Whaler Rage VRO problems
First sign I got of the VRO pump failing was it over oiling. Fuel side could be suspect.
bkwapisz
ty,
New VRO is $300-400. Just had identical problem myself. Disconnected oil side and just am using fuel side with 50:1, but I am out of time here in Michigan as the weather's getting cold. Have to put it away for now and over the winter I plan to convert to a regular fuel pump and do away with the VRO totally. Search on here there are a lot of threads on it and in a days time you'll be an expert on it.
sure would help to know what motor you have. i have no info to work with.
