help with new to me boat purchase
66mstgfsbk
need pros, cons and opinions about following boats.
2000 maxum 2300 scr with mercury outdrive
1999 four winns sun downer 245 with volvo duo prop
thanks for the help
QC
Re: help with new to me boat purchase
My guess is that the Maxum is an Alpha Drive. If so, I give the edge to the Volvo if you can get service easily in your locale. I like Maxums, but I believe the Four Winns is probably a little higher quality. I know the SCR and it can handle reasonably big water and has a lot of stowage. I do not know the Sun Downer, and I am curious about the deadrise (depth of V). Where are you going to boat?
66mstgfsbk
will be boating in
ca delta, sf bay, tahoe
here are some specs i found on the four winns it was in a old brochure
loa 24'2
beam 8'6
transom angle 15deg
deadrise 20 deg
keel to w/s shelf 6''
freeboard(min) 33"
draft (down drive) 37"
draft (drive up) 20"
280 hp
4000lbs dry
44 mph @4500 rpm @ 20 gallons per hour
Dave1251
With boats this age, the care and maintaince is the most important factory in the selection. However, if both boats are well care for, then the Four Winns is a much better built boat. Maxums were produced by Brunswick and some were made in the Bayliner factory. They also used very cheap hardward.
As for Merc vs Volvo, if the both are dual props, than its a toss up, if the Merc is an Alpha 1, then the Volvo DP is a much better drive.
QC
20 degree bottom should be relatively equal in rough water. I am leaning pretty hard towards the Four Winns depending on condition as Dave has noted. Should have no problem with service in your general area.
66mstgfsbk
if i were to launch out of long beach would any of those two make it to catalina safely of will i need a larger boat? thanks for the help
