15 hp evinrude cooling problem and id
SWIFT HALF
:mad:hi i have just brought a avon 12 foot plus a 1 hp evinrude i was told it was an 80s model but when i have put the model number in the net cant seem to find the year the number is[be15balcob] can anybody id the year so i know what im ordering in parts . now to the cooling problem i put it in the water today and found it had no water coming out the pee hole phoned the guy who i had it off and he said it could be blocked and to stick some wire up it to clear it did this but found a small drible of water but then it stoped so i turned the outboard off as it was not cooling any advice please thanks matt
Don't know what you changed, Matt, but this is what I meant:
Hi. I have just bought an Avon 12 foot plus a 15HP Evinrude. I was told it was an 80s model, but when I have put the model number in the net I can't seem to find the year. The number is BE15BALCOB. Can anybody ID the year so I know what I am ordering in parts?
Etcetera. Editing the whole post is more work than I am up to this morning.
JB
Re: 15 hp evinrude cooling problem and id
First piece of advice: Please spell, punctuate and capitalize your posts as you were required to pass grade 5. It make them much more readable and you are much more likely to get serious responses. As is, your post tells people that you are either illiterate or don't give a hoot about details. Neither inspires a response.
I think your engine is a 1985 Belgian made, long shaft.
rickdb1boat
BE=Belgium made
15=HP
BA = AC Lighting - Rope Start
L=Long Shaft (20")
CO=year 1985
B=Model run
I would suggest replacing the water pump if it's unknown when it was last done..
SWIFT HALF
Said by the man sat on his porch playing the banjo with his teeth falling out and holes in his shoes .
SWIFT HALF
thanks for the advice mate will do now i know the year of production .
bktheking
Dude how did you know JB played Banjo??? Him and I have a Banjo band in Texas together, you know down there in the back woods. You should come by some time, we can teach you how to play too!
bktheking
Ok seriously now to answer your question, JB beat me to it, usually I point out the bad punctuation and spelling before he does. You are posting your question to a bunch of retired OMC mechanics and current mechanics who take the time to reply to posts, I guess they just don't like wasting time reading a bunch of run on sentences. Half the time I re read my posts 3 times to make sure all is well, correct grammer and spelling.
To address your issue (and i'm not expert) but I know enough about these motors to warrant some advice. That tube for the telltale travels up to a 90 degree plastic fitting on the powerhead. Not only does the tube get plugged but so does the plastic fitting. First advice anyone on here will give is to replace the water pump, it's the bloodline to the motor. They aren't hard to change and if you search the forums the topic has been covered 100 times.
Cheers
oldrudedude
If I had $5 for every time i've wanted to say that............
SWIFT HALF
dont fancy playing the banjo but i will bring my washing board we can have a jam lol ps thanks for the advice
bktheking
No worries, wash board LOL, good stuff!
SWIFT HALF
Have now fixed it, back flushed it and took the pipe of and found lot of salt it looks as if the last keeper did not look after it .All smiles now thanks for your advice all
jay mendoza
Well, you most likely have quite a bit of salt and corrosion inside the block. It's not too hard to remove the head, and with a 1/8" drill you can clear the water passages of the block and head, probably is going to need a thermostat too, so get a head gasket and thermostat cover gasket and seal. There are also treatments that are supposed to remove salt and corrosion deposits, but in severe cases it's best to clean the block and passages manually.
The rebuke you got surprised me, but rest assured that I don't mind poor spelling.
