Tohatsu 5.9 high thrust prop performs miracle
tommays
Seafever was broken down on a mooring in NYC and had to be moved over 12 miles to Glen Cove
Having only a 4Hp outboard to work with ,which was good becasue it was a PITA hanging it off the back of a 29' boat
SO we did really not know what to expect BUT it moved a 29' 8000# boat with a dirty bottom and a fixed two blade prop at 4.5 knots :eek:
pvanv
Re: Tohatsu 5.9 high thrust prop performs miracle
That's a good result. I might have expected 4K or so; To get up to 4.5 is very good indeed. Must have been a calm day.
I spec Tohatsu/Solas HT props for the 4/5/6, 8/9.8, and 15 frequently for sailboats (mine included), and have had good results. My 8,000 pound sailboat uses a 9.8 with HT prop, and I make 5K all the time.
It's surprising that the stainless swim ladder didn't distort too much under the thrust from that rig.
TOHATSU GURU
That propeller is not offered by SOLAS and is made by Tohatsu....
Sea Rider
When you pushed that 29" heavy sail boat with that engine, what throttle amount were you using ?
We are using Standard Tohatsu's 3.5 long shaft to push J-24 sail boats. Would it be advisable to use max 3/4 throttle on calm waters to push haevy sailboats regardless of the engine being used ? Please advise.
Happy Boating
tommays
funny because i have a J24 :) and that is the motor i used to move the CAL
The stock 7" prop moved the J24 at 6 knots at just above 1/2 throttle and in fact there was no more performance when i had a 6 hp Johnson
The 5.9 high trust is amazing and allows the motor to reach far more RPM and looks nothing like the 7" prop
It was almost like a jet drive the motor spun up and a few seconds later the Cal started moving and took about 1 minute to reach 4.5 knots
Sea Rider
So 1/2 to 3/4 throttle would be the way to go with a Tohatsu 3.5 HP pushing a J-24 sailboat with a standard factory delivered prop, right ?
Happy Boating
tommays
I think stock would work BUT if they make and HT prop fro the 3.5 it would be far better as the motor could reach its proper RPM
TOHATSU GURU
No high thrust prop available, but, switching over to the aluminum prop would be better than using one of the standard plastic props. The aluminum prop would be less successible to deformation from water resistance.
