Need Some Help On My 1960 or 1970 Something SS Resto!!!
Huron Angler
Re: Need Some Help On My 1960 or 1970 Something SS Resto!!!
Looks great Pauly:D I agree with EZ on the bow stripe, the line wants to keep going in my mind and it would look a bit sleeker possibly.
Wow...that fiberglass rig sure looks jealous of all the attention the aluminum boat(The Black Pearl?) is getting:D:D
PaulyV
I had the bow all black (where the white is now) and it looked odd to me to have the white stripes just stop on each side, so I continued the white to connect them.
Are you saying carry the stripes to meet at the seam, and paint the upper nose all black..or stop the stripes (port, starboard) and leave the whole nose black.
Nothing wrong with experimenting..I wish i could mess around with it on a computer tho..
By paulyv, shot with KODAK Z650 ZOOM DIGITAL CAMERA at 2010-01-21
CheapboatKev
Sure does look good..
Great work..and ya dared to be different on the paint...thats what makes it yours!
Ya never said where ya scored that (now) bitchen black wheel from?
PaulyV
Thanks Kev! I do have a few more tricks up my sleeve for the paint...:cool:
That Dino wheel I scored on EBAY..$15 sheckalinneeees. that plastic coat is real nice stuff. The wheel is still rubber and feels great!
ezmobee
Here ya go
pmillar
Another alternative on the stripe would be to carry the white down in a sort of V at the bow. Sort of follow it down to the keel (at least to the water line.)
And man, great work. I just read through the entire thread.
sprintst
Damn man. That thing looks like it could float :)
The end is in sight...
Huron Angler
Ya mean something like this? This is a 1969 fiberglass rig from another thread.
attachment.php
PaulyV
Interesting...fits that style boat perfectly..
PaulyV
Ok..I used 5 1" sheets of pink and 1 2" sheet. Thats about all I could make fit without going too nuts with custom fitting. I may use some 2" on port/starboard on sides of hull (lower section). This may dampen the noise as well. heres a few pics of the floor install.
By paulyv, shot with KODAK Z650 ZOOM DIGITAL CAMERA at 2010-01-23
Proof there is flotation installed!! Sledge hammer is for intruders..
ezmobee
Looks great! I assume those rivets are working well for you....
erikpn
Have you thought about seats yet? I am hesitating to rivet the remaining parts of my deck because apparently, a backing plate or other anchor system should be used under pedestal seat bases to attach them securely. I'd rather do that now with regular bolts and fender washers than have to drill access holes later or use expensive toggle anchors. And my original plan to screw down seats is out the window. =s
ezmobee
I added plywood blocks in the general area under where my pedestals are going to go so I can just use lags.
PaulyV
My seating is already established, front of console seat and seat at helm which can seat 2 ppl (both girls or wife and 1). other than that straglers can ruff it on my no skid deck..:D
PaulyV
Yes they worked out well..with the exception of the ones that go into the ribs on the edges. The rib is thicker aluminum and altho the rivet bites..it is not enough to be permanent. I have had a few pop up after walking around the deck. I will use some stainless screws to address that area. They are fine for the stringers with no issue. These are pretty impressive rivets I cannot imagine going to a 1/4" that is way overboard in my opinion. Let me know how many youll need, I used no where near 100 for my deck.
PaulyV
Here is what I want to do. I will gain 10" in the back of the boat. Altho that doesn't sound like alot...it is!! Thats where my downriggers will be mounted one each side...and that 10" really allows some elbow room.
I dont see the need for such a HUGE splashwell. I would like a few opinions.
By paulyv, shot with KODAK Z650 ZOOM DIGITAL CAMERA at 2010-01-24
ezmobee
Yes they worked out well..with the exception of the ones that go into the ribs on the edges. The rib is thicker aluminum and although the rivet bites..it is not enough to be permanent. I have had a few pop up after walking around the deck. I will use some stainless screws to address that area.
Ok, I was on the fence anyway about using the rivets. I had used deck screws on my Jupiter and they worked great. This was all I needed to be pushed fully in that direction. Rivets-shmivets :p
ezmobee
I think you could probably do that. The only issue I can think of...is the upper motor mount bolts I believe sit pretty close to the bottom of the splashwell. Your shortening of it looks like it may raise the well up to somewhere in the general area of smack in the middle of those bolts. That could be a pain. Also I assume you'll be able to bend new mounting "tabs" in it.
North Beach
Pauly and E I owe you guys an apology! I went back and looked at my restore thread and I used 3/16 rivits with a 1/2" to 5/8" grip range. The 1/4" rivits were mis ordered and returned. When you folks asked the question, I went to my file and pulled up the wrong receipts. Again, sorry!!!!!
