Honda bf90 backfire
n628ms
I have a 1998 bf90 that backfires through the carbs when you accelerate. Rebuilt the carbs with no success. Clean fuel and filter.
Any suggestions?
n628ms
Re: Honda bf90 backfire
Thanks for the reply. I would have thought the same thing but the manual says that the timing can't be adjusted.
n628ms
The marks on the crank and camshaft line up properly. Is there an adjustment on the electronic pick-up?
n628ms
I did another test run and when I accelerate it bogs down. If I choke it real quick it picks up then dies off again. I tried to set the pilot screws for a richer setting but did not notice an improvement.
Sea Dawg
Your last post feels like deja vue. I just bought a used 98 BF90 and currently am going through the same scenario. The motor doesn't want to turn over so I hit the choke only for it to turn over and slowly die; it never holds idle. The previous owner had fuel issues as he predominently used ethanol. So I assumed there was a lamination / gumming up issue so I dumped all the old fuel and replaced the fuel filter only to be at sqaure one with the idle issue. Were you able to get your issue resolved? I'm curious if it was a timing issue If so what was your solution, I may be in the same boat; no pun intended.
n628ms
It idles great. It only bogs down when you accelerate and it backfires. If you rev it up slowly it does not backfire unless it is under load. I still think it is carb related.
psteurer
We have two posts going on for a BF90. Both appear to carburetor related. For the first post from n628ms, did you synch the carburetors after your rebuild? If not, that could be causing this problem. For the second post from Sea Dawg, sounds like your carburetors are clogged. Old fuel sitting in the carburetor will clog the tiny ports where the fuel passes. From your post, it sounds like your idle circuit has the problem but it could be elsewhere as well. For preventative maintenance, it is advised that you drain the carburetors of fuel if you plan to let the motor sit for more than 2-3 weeks. Also, run some fuel stabilizer in your gas.
n628ms
Today I sync'd the carbs. It ran a little better but still backfires through the carbs. A local guy told me that the low speed jet tubes might be cracked. He says that it happens alot on Honda's. Also, has anyone heard of this problem being caused by bad valve guides?
n628ms
I guess it would be sneezing. I don't actually see any fire.
JUSTINTIME
pull the carbs off
you need to remove the 2 jets and the pilot tube
use an ultrasonic cleaner
then use a fine brass wire to ream the inside
n628ms
o.k.. I cleaned the jets as you suggested even though they looked really clean. Put everything back together and it still sneezes out the carb. Is there any chance that the valve guides are bad? I am getting the for sale sign ready. Haha
n628ms
did you remove all the parts in vcarb
Everything I could remove I removed. I even blew out all the passages with an air hose. Everything appears clean. I asked a local Honda mechanic if he thought it could be valve guides or springs and he said he has never had to rebuild a head that wasn't caused by overheating.
hondon
Has anything been done with the accellerator pump side of that manifold?A leaking diaphram or stuck check valve could cause your exact problem.Keep in mind that these engine were designed as utilitarian and really do'nt like to be stood on,but if its acting differently than you are used to you might consider looking at that pump assembly.
Wheelhouse
It sounds like you have a vacuum leak on the engine side of the throttle plates. When the engine bogs down will it pickup if you choke it? Choking it makes the fuel mixture richer. With the engine at idle, spray some WD40 around the Carb bases and where the manifold connects to the head. If you have a leak the vacuum will suck the WD40 in.
