1984 evinrude 15 hp
gabriel323
Re: 15 hp evinrude
Re: 15 hp evinrude
mine is also electric start does it need to be hooked up to work with the pull start cable:confused:
bktheking
Re: 15 hp evinrude
Re: 15 hp evinrude
Check compression first. Then check for spark, getting it on both cylinders? If yes then it could be fuel related.
gabriel323
Re: 15 hp evinrude
Re: 15 hp evinrude
checked compression every thing is good but I don't have a spark what do i do:eek:
gabriel323
1984 evinrude 15 hp
I 1984 evinrude 15 hp I checked compression and fuel looks good but I have no spark. I'm new to this can some one please help me.:(
bktheking
Re: 1984 evinrude 15 hp
The first thing I always suspect with these motors is the power pack, they blow and then no spark. You could also disconnect the ground wire on the switch and test for spark and check the ground at the powerpack for corrosion. Powerpack is at the back right hand side of the motor. You will need to get a manual and the appropriate testing tools (DVA I believe) and test out the pack. Or you could bite the bullet and replace it and see if it fixes the problem. I have a spare in the garage for testing. But check for what I said to check first before dropping ninety bucks on a powerpack, could just be a bad switch/ground/broken wire.
mikesea
Re: 15 hp evinrude
Re: 15 hp evinrude
disconnect the kill switch and recheck,they go bad,as do the saftey lanards on the newer engines,its possible you have a bad powerpack,but i see more switches than packs be the culprit,let us know
gabriel323
Re: 15 hp evinrude
Re: 15 hp evinrude
I changed the power pack I still dont have a spark what can it be :mad:
gabriel323
I changed th epower pack still no spark do you know what else it could me
kill switch??? corroded connections, bad ground.
mikesea
agree with TASH,your kill switchh is a lilely suspect,disconnect and try,you will need to choke to kill.Let us know what u find
mikesea
Re: 15 hp evinrude
Re: 15 hp evinrude
have u checked the kill switch
bktheking
It's the first thing I said to try, disconnect the ground wire going to the switch, then test the powerpack, not sure why people just go and replace expensive parts instead of testing things out first.
kbait
Re: 15 hp evinrude
Re: 15 hp evinrude
and your other post?
i have merged your multiple threads, use only this one thread. multiple get confusing to you and the members.
Elbo
I have a 1972 goldtop.
