micks110
Thread starter- Joined
- Sep 14, 2009
- 879
Re: 1962 Arkansas Traveler restoration
Thanks Guys!
Again- being totally new to steering and this boat stuff, shouldn't I have full motor travel from side to side?
Is teleflex the way to go or should I stick with what I have? What is the big difference?
There is a pin hole area on the wheel- you can see it in the one picture- I will try that tonight to get the wheel off?
EZ- I have a bar on my motor- not sure if it's the one they talk about in the fresh water kit.
Arch- There is a wiring diagram on the inside of the uni-charger case. That thing is so old school so even I can understand it
The wiring harness or connecting the accessories that I want is where I will be confused
I was thinking about the boards under the cap last night and was thinking the same thing you just said- I am going to keep them there and just add fresh glass to them and half tube supports in between them.
Thanks santo- I will be looking at it a bit closer tonight!
Thanks Guys!
