fletchermerc1996
Thread starter- Joined
- Nov 24, 2009
- 19
Hi guys,
I am new to the boating game and have a couple of questions I hope you can help me with.
I recently bought a 18ft Fletcher with a Mercury 135 hp 2.0 litre v6 black max outboard. The engine is believed to be early to mid 1990's model.
Hope you can help!!
The autolube has been disconnected and the previous owner was pre mixing the fuel. The autolube system is still function, well so I've been told. How reliable are these systems? The previous owner stated that he would rather pre mix, but are these systems generally worth while using, and are they generally fitted with an alarm if the oil stops flowing?
How could I possibly find out exactly what year the engine was made? Is it printed on it somewhere, or could this be obtained from the serial number?
What general fuel consumption would you expect from this size engine with a 50 litre tank? I know it depends on how your driving her, but at cruising speed, roughly how many hours of use would you expect?
I've been told by a mechanic that replaced the impellor and t-stats that there is a slight fuel leak either into, or around the carburetor... Is this a common problem, or rather serious?!!
Thanks once again for reading, and look forward to hearing some of your experienced opinions!!
Hope you can help!!
