deflector hose replacement / both heads
juandapoolboi
how many deflector hoses do i need to replace all of them part#18-0892
1983 johnson 115 crossflow. Are you supposed to cut this part to length ??? or purchase 4 ? also if this fix dosent work i was thinking a or both?,sensors should be replaced new pump entire kit stats springs . thanks again.
ezeke
Re: deflector hose replacement / both heads
You can purchase four pre-cut ones and trim with a razor blade. Or, you can purchase the hose and cut them yourself.
http://www.iboats.com/Johnson_Defle...8577270--**********.462770819--view_id.271462
Temperature switches rarely go bad unless the cylinder head has overheated a lot.
You should service the thermostats - complete kit is part 18-3673.
http://www.iboats.com/mall/partfind...gd_poid=111072&gd_row=31&**********=462770819
See: http://forums.iboats.com/showpost.php?p=2227551&postcount=2
