Hi all
I am new to this forum and also new to boating . I am not sure if I am having trim problems or if I am just doing something wrong. I have checked the pump reservoir and filled it to the proper level as directed by the owners manual.
Here is my problem , I am unable to get the boat motor to trim up or down. When I press the trailer switch , I can hear the motor or at least a strong sound that tells me something is trying to be actuated . However nothing happens .
I have pushed the trailer switched and depressed the up / down button at the same time but again nothing happens. I believe that the unit does work because when I picked it up , the motor was in the full up position without a transom saver holding it in that position.
I have lifted this monster 300 pound motor manually many times to put the
transom savor back in place , what a job that was . I then found that by turning the small knurled knob at the trim pump that it would raise much easier , but again , will not stay up by itself. I am at the end of my rope here
and hope that someone can walk me through what I must be doing wrong.
Is their a lock of some type on this motor that locks it in the up position for trailering , if so , where is it ? And is there a chance that it could still be in the locked position and is why the trim will not work ?
My Boat is a 1983 Skeeter Starfire 115 with 115 HP two stroke Mercury outboard . Sn# on engine is 6300471 .
Thank You all in advance .
