1987 Four Winns 215 Sundowner Refit/Repower
Re: 1987 Four Winns 215 Sundowner Refit/Repower
Honestly, how many beers had you had prior to running that truck into the pit at a 45 degree angle?
Boat is looking good.
solar7647
I had 0 beers, thats a sober move:eek:! I new I had to drive over it, I have had to do it a dozen times, it sits in an odd place on the floor. You would think it would be centered in the path of the door way but its off set and because of that its hard to miss. I guess the cap was just to old to hold weight anymore!
I dont drink while working on the boat, I wait till after to reward my self for a job well done.:D
fat fanny
Good idea and smart move on your part! I'll let you figure out which one! ( juast razzin ya )
solar7647
Lets figure this out::confused:
Good Idea: Rewarding ones self for a job well done
Smart Idea: Not drink while working
Or
Good Idea: Using over head gantry to lift truck
Smart move: Using oak to support truck over the pit
Or
Good Idea: Not drinking and driving
Smart move: Way to drop your truck in the pit stupid, maybe you should have been drinking, you may have missed it!:D:D
solar7647
well i forgot to get photos of my work today so I will have to take them tomorrow and post them tomorrow night.
But I got the helm all assembled and installed the new rotary steering system and i must say it works great, so much smoother then the old rack and pinion system.
I also lifted the engine so I could install the new spring lock washers and leather spacers on the rear mount. Since I had the engine up I painted the bilge, inside of the transom and the surrounding deck. The area I painted will be the engine compartment, I am going to put in a straight bench seat in the back that will sit in front of the engine and put a sun deck over it. No more dog house, I hated how cramped it made the engine compartment.
fat fanny
Solar I love your annalogy of the pit situation but I do believe a guy deserves a beer after a job well done. But knowing how many is even a better job done!
solar7647
Well today was a wast!!!! I was planing on painting the bottom of the boat, but is so humid from this rain that the concrete floor of the barn is sweating and keeping the bottom of the boat really wet!
I did get the trim pump in and some wiring done through and a second coat of paint on the bilge. I guess next weekend will just be double tine!
But hear are the photos of what I got done last night and today.
The dash all hooked up
the nice and clean bilge
solar7647
I am getting another x-mas with in the next week:D I just got done with a shopping spre:
New Helm seat
New passenger seat
New trim tabs
New wakeboard tower
New Trailer tires
New Trailer axle
New pedistolls for the seats
New engine allinment tool: found for $35 on amizon.com:D
I am really happy with the deals I got!
The seats: The reveiws said it was confertable and they have a small turning radius, plus i need something that isnt going to get trashed fromo fishing. The big plus only $100
The pedistal: every thing you see, 360 swivel $58
The tower: I went through a ton of reading and reserching and this one, I think will give me the best look and the most bang for my buck, only $800 and free shipping:D It will fit up to a 108" beam so it will fit really good.
solar7647
I cant wait to open them all!!!!!!!!!!!!
smitty1258
did you get any ballast?
or are you relying on the tabs?
cant wait to ride behind her!
solar7647
No ballast...she has a fat a** as it is so just using the tabs should be fine. I will def. host a wakeboard outing this summer it will give time for your and chads boat to rest:D
solar7647
I got a bunch done today...I finished a bunch of wiring done. I installed new switches, that have indicator LEDs in them. I got all the lights wired, the horn, blower and trim pump wired to. I got a new battery and case in today also.
Once I was done with my wiring I sanded the bottom of the boat and painted it also. I had to paint more of the bottom black then I originally wanted due to a mistake on my part. I damaged the white paint on the bow above the water line and didnt have any more white, so i brought the black up higher to cover it.
The new switches
Gauge lights
The battery and blower
The new horn
The bottom paint
I have used all Rustolium paint on the boat and am very impressed with it...bottom and top side paint. Cheap too.
solar7647
I was able to get the rear side panels built today and the bench. I also got the sun deck mocked up. I need to make a trip to the hardware store to get mounting hard ware for the sun deck through. I also got the door frame done for the cabin. I am going to finish the side panel and get the hardware in so I can seal the wood. Then i will need to button up some stuff and install carpet and cushions and all that fun stuff.
solar7647
Does anyone know of a place that sells cushion foam at a good price? I have found a couple place that are ok prices but I would like to find a better deal.
I was thinking 2" for the seats and 1/4" for the side panels and other peices of wood that will need covered.
ltjag101
i used foam from an old slide in camper to build my last boat and it just so happens the other day the wind picked up my buddys slide in camper and tosed it on the gound.:eek: so i will be getting the foam out of it for the seats on my new project.:D i have heard of people using couches and baby matresses.:confused: just make sure you put a few holes in the plywood to alow the air to escape. if you dont you will end up with long lasting but imprints.:( and what ever water makes its way threw the vynil will get out there also;)
just a question about the foam for the side panels what about that hypoalergenic foam carpet padding for the pannels it does not alow moisture to penitrate the surface that was my thinkg for my side panels 2 layers of this stuff. super durable and firm:D
solar7647
The issue there is I dont have anything I can steel the foam from....I was thinking about poly foam Its got a good price, I just am unsure on how firm it will be.
http://www.thefoamfactory.com/opencellfoam/poly.html
solar7647
Oh yea the Fed Ex santa clause came to my house today!!!!:D
Got the wakeboard tower and the engine alignment toll!
I should get more tomorrow!:D
ltjag101
wow that tower looks amazing caint wait to see it put together and about the foam talk to your fabric guy he might be able to get prices you or i can not my brother bought some at joann fabric but wow was it pricey and a week later we went in there and all the foam was half off luckily my brother still had his recipt in his pocket and got his money back for the half off i belive they run a half off sale evey other weekend on foam
on there web site they have foam in 2"x10' 18" and 24" 55.99 and 71.99 but i think it could be bought cheeper at a local store intead of on line
MTribe08
Who is the tower made by? Where did you get it?
solar7647
The wake tower is made by DIY Wake, I ordered it online and they shipped it to me. They offer free shipping on all their products over $100. I orded it on Thursday night and it showed up on Tuesday so its fast free shipping even with it coming from California to Ohio.
A link to the site
http://www.diywake.com/shop/shopexd.asp?id=616
