115johnson wont run in run pos.
joeconroe
1996 johnson outboard runs and idols in start position but not in run position.i have replaced the ignition switch and the rectifyer. there dose not appear to be any shorts in the ignition switch wireing :confused:
joeconroe
Re: 115johnson wont run in run pos.
the problem originated before i changed out the ignition switch. one day the engine was running fine ,it began to idol rough, then it would not idol,but it would run, then it ran at high rpm then shut down. thats when i discoverd it would run in the start position.:confused:
joeconroe
Re: 115 johnson wont run in run pos.
Thanks for the input Tashasdaddy and Ezeke, I will check out cdi electronics and let you know the results
