Yamaha 15hp go go faster than idle but will rev
fishin&crabin
1998 15hp Yamaha. Pulled up to shore put in neutral but it stayed in gear had to pull kill switch. After shut off went into neutral. When restarted goes into gear and revs up but only moves at idle speed. Could have hit relatively sandy bottom when first problem occured. Any ideas what could be wrong?
joey maneri
Re: Yamaha 15hp go go faster than idle but will rev
Maybe check the linkages to the carb and the spark advance, could be something simple.
fishin&crabin
Thanks I'll check that. But it's weird revs out like I should be really moving but just barely going anywhere.
99yam40
sounds like you spun the hub in the prop
