I think this may be the most anticipated splash on iboats.
The fuel filter should be full or close to it during operation.
What model carb and does it have a filter that screws into it at the fuel inlet?
What happens if you slowly advance the throttle, same thing?
I've come out of hiding to see this splash. Boat looks great, Jas! I know you will get the fuel delivery/throttle issue figured out soon.
Glad to hear you got her out on the water, but you know the rules no pictures it didn't happenAfter spending 30 minutes looking back through the 405 pages I believe you have a Rochester 4 barrel on the 4.3. I fought with the one on my SS201 and just lost another battle with the one on my Rat Rod. If the barb has sat for any length of time with gas with ethanol in it the carb will have very bad corrosion in some of the ports that carb cleaner won't remove. In both cases I ended up purchasing an Edelbrock replacement in your case it's a 1409.
Howdy! Yup, I actually bypassed everything and rand the engine directly off of a fuel can and the engine ran the same. So, I know I can rule out fuel lines, filters, tanks, bad gas all that stuff.
It's got the 2 barrel and I dunno:noidea:
Yup, same thing happens, at 2K it kinda wants to stall out.
Great to see ya PMC!
Alrighty, I'll post up a few photos here in a sec:eagerness:
Actually, I've got the 2 barrel carb on this one. So, new carb ya think??
Depends how bad it is, gas with ethanol in it is really bad for carbs that sit. In one of my Quadra jet 4 barrels it ate the entire seat out around the steel ball in the accelerator pump base, as well as through the bottom casting.
