Panfishangler1
Thread starter- Joined
- Jan 20, 2010
- 30
Hey there.
Motor: 1983 15hp Evinrude 2 cycle outboard shortshaft.
History of motor since Ive purchased it about 2 months ago: So since then I have changed the spark plugs twice, added new seal/gaskets to all the parts including Powerhead. Replace Grommets for exhaust/water pipes, new impeller, added thermostat, new prop with higher pitch, unglogged and cleaned parts where the water is supposed to circulate. New Spring coil for pull start!, and I was told from seller that the carb has been rebuilt along with new fuel pump. I also purchased a seloc vol.2 manuel, but its really unhelpful.
Problem: After taking motor/boat out for a day (everything is working). Get it home and clean/store away...... So, One week later I get the boat out, and the motor will not start. ? No matter how many times I pull the chord, nothing kicks on? And once the pressure inside builds up, the motor backfires. I believe it backfired out the propeller, and carburator at one point.
So, my list of things Ive checked:
-Spark Plugs and battery packs are producing nice blue sparks.
-Fuel is getting to the fuel pump and into the carburator.(the more times you pull the "pull start" gas seems to build inside the filter where the carb lets out.
-Im not sure if fuel is getting inside the power head though?
- unclogged the exhaust pipe and water pipe.
- All the plugs are hooked up correctly as stated above....
-So :/ after doing everything, I have had 3 failed attempts on getting this motor to fire on. Its like a create a hypothesis, go out and prove it, then fail.
So thats pretty much the best /fastest way to explain the issue. Any help would be awesome. I have spent a huge great deal of time, and money so far by just working on it myself. So, thats why I have no idea what to do. And yes, I am a first time boat owner, but after pulling that power head out, Ive learnd alot.
Thankyou for your time,
Andrew
Andrew
