1990 Force 120 carb question
KenOverton
Re: 1990 Force 120 carb question
Thanks for the assistance everyone. Got everything back together and I am now able to adjust fuel mixture on both carbs. Had the boat out 2 times now and it runs great. Had to set idle a little on the high side to prevent dying when shifting into gear, but that is not an issue to me. Idle is set at 1000 - 1100. Will a standard auto test tachometer work on an outboard ( the kind that connects to the spark plug wire)? I have one of those and my timing light has the tach feature built in but both read way higher than my boat tach.
I know now that the motor is under-propped. I have to make sure my tach is working correctly and then get all the numbers to try and figure what prop I need. At full throttle it buries the tach past 6000 and there is major prop-slip. I don't even have to trim to get the boat on plane. Like I mentioned, I will have to get all the numbers and post that in the prop section for some assistance.
Thanks for the help.
Ken
itzmepete
Recommended rpm is between 5000 and 5500 is max rpm. Idle is with boat in gear . My 1999 120 force idles at 1000 to 1100 but its at 900 to 950 in gear. A regular car tach won't work or I should say has to be set up right. I think if you have it set for a 4 cylinder it will read twice as high as a two stroke fires double than a four stroke. Try setting it up as an eight cylinder.
I need to take my float bowls off as I suspect some dirt in there. Engine starts/runs great at any speed, WOT is 5250 which is max for my 99 but when I tilt it up it slows and stutters. Tilting it up brings the bowls level and I suspect some dirt in the bowls may be sliding down onto the jet tube area. I had a Volvo Penta that when throttled up and the nose of the boat went up it did the same thing. Ended up being dirt in the bowls. Just took a quick look at my carbs bowls and did notice a line connected to the bottom or at east I thought I did. What did your bowl set up look like and what did it entail to pull the bowls off?
treat44
Agree x3 here , clean the bowl , make sure the vent is clear , carb cleaner through everything else and let 'em run ! I just did new idle tubes on mine , What a pain but I took the cheap way out , hobby shop for tubing stock and made mine . I will never pull them out again !!
Can you elaborate on what size OD, length tube, etc. you used for your idle tube fix. New to carbs, I was referencing my Merc manual which states to press out idle tubes. I ruined one and need a fix. Part not available through dealers?
