KenOverton
Thread starter- Joined
- Jan 27, 2010
- 40
Re: 1990 Force 120 carb question
Thanks for the assistance everyone. Got everything back together and I am now able to adjust fuel mixture on both carbs. Had the boat out 2 times now and it runs great. Had to set idle a little on the high side to prevent dying when shifting into gear, but that is not an issue to me. Idle is set at 1000 - 1100. Will a standard auto test tachometer work on an outboard ( the kind that connects to the spark plug wire)? I have one of those and my timing light has the tach feature built in but both read way higher than my boat tach.
I know now that the motor is under-propped. I have to make sure my tach is working correctly and then get all the numbers to try and figure what prop I need. At full throttle it buries the tach past 6000 and there is major prop-slip. I don't even have to trim to get the boat on plane. Like I mentioned, I will have to get all the numbers and post that in the prop section for some assistance.
Thanks for the help.
Ken
Ken
