LoneRanger!
Thread starter- Joined
- Jan 28, 2010
- 3
I am coppying this from the etec owners group forum in hopes of getting some help here!
My tilt and trim unit is not working! at ALL. Nor does my ignition, nor does my tach. I have almost NO corrosion. I am using an evinrude tach and a Teleflex binnacle mount, I have the modular wiring harness, and the modular wiring system key switch. I am using all this with a 2009 25 horse etec.
when the key is on I can pull start the motor no prob. turn the key off the motor turns off. the tilt and trim I have no idea, it just quit working. again, no corrosion, and that is a straight run back to the motor via the harness) I have #4 battery cable going straight to
the motor no fuses or switches.
I am not concerned about the tach or the ignition, but how the heck do I get the tilt and trim to work?
there is a single 10a fuse that is under the cowling; that fuse is PERFECT! I figgured there had to be a fuse somewhere on the motor and I found that one- it is in exellent shape.
to note: when I try the tilt switch I dont hear any type of relay or pop/ clicking sound. same goes for the electric start.
thoughts?
L.R.
PLEASE HELP!
_________________
thoughts?
L.R.
PLEASE HELP!
_________________
