Thread starter- Joined
- Nov 11, 2005
- 51,019
Re: still stumped. 1989 175GT
rain here for the Day. tomorrow.
TD said:compression +- 2 from 100 psi. used test tank, drained main tank, new fuel. wiring is 100%. yes, know all about troubleshooting, before, parts.
you were correct, how do i fix it???
i think this is the problem, it throws the timing off, as when i check the timing it was way off, adjusted it, but now it is really rough. there is obvious evidence the timing has been messed with. the distance the timing was off, coincides with the magnets.
I don't know any way of repairing it that I would want to guarantee, so unless someone else chimes in, I would consider looking for another flywheel.
That particular flywheel is used from 1989 through 1992 on the 150 and 175.
See if Dale Hadley knows a good way to glue them in place.
Dhadley said:The outer magnets being loose will not change the timing but the center hub magnet being loose will do all sorts of bad things.
Hmmm... interesting. I had an older J200 that I couldn't get in time to save my life... and the stator was also producing close to 500 volts. Many of the outer magnets on the flywheel where broken producing to many poles, and the overvoltage. And the center hub was also spun, hence, couldn't get a correct ignition timing.
I replace the flywheel, and the stator (because it was half fried from over voltage) and that motor was fixed.
I'm curious. The outer magnets run the cap charge coil and bat coil, but If the center hub is spun then the magnet is going to swipe the trigger either to early or to late depending on which way it spun. At least that's how I understand it. If i'm wrong please tell me how the inner magnet can spin and not throw out the timing.
