twostroke87
- Joined
- Nov 15, 2008
- 137
Re: still stumped. 1989 175GT
You said that you tried it at the ramp, I'm assuming that the control box uses that little idle lever which is completely useless when there is a running problem.
Have you tried backing it in at the ramp, starting it and getting it to idle.
Then (you might need one person up front if it is really bad) Put it just into gear, then disconnect the cable at the engine, and take control of the throttle by hand (make sure you grab it so the timing linkage is moving also) And try fast pumping the throttle at much higher and fast rates than that little idle lever does, also possibly try pumping the ball while you do this.
I had a similar problem with a johnson 115, it ended up being a combination of 2 different things, the coils although they had spark it was intermittent, the wires were cracked and breaking, and all the grounds needed to be cleaned.
On top of this, one of the power packs was bad, and was also intermittedly working.
