help removing sealant off hands!
coolguy147
i used some 5200 3m marine sealant and got quite a bit on my hands.
i got most of it off but on my fingers i just will not budge. used goo gone. lotion. soap. hot water. more hot water....
i386
Re: help removing sealant off hands!
You can pick it off with your fingernails (about this time next week).:D
Bucks45
Paint thinner or gasoline (hope you don't smoke)!:eek:
ezbtr
diesel or gasoline...........
Bob_VT
Scrub your hands with a green scrubbing pad...... eventually it will wear off...... Just a hint.... it does come off easier then fiberglass resin.
So what kind of shape are the gloves in......... you should have had on your hands? :D
Tim Frank
Peanut butter.
Rub it on, put on disposable rubber gloves, watch your favorite tv show, remove gloves wash off PB.
WD40 is also reputed to work.
rbh
Once the oils in your skin come out, it will just peal off.
Fly Rod
Acetone, works great!
ezmobee
It's your penance for becoming a Merc fanboy! Take that traitor! :p
Ayuh,... I've found the Perfect thing to remove stuff like that,...
Most generally, I'm about elbows deep into many Nasties, pretty much Daily,...
What washes off with GoJo is gone before dinner,....
What Doesn't come off with the GoJo, comes off with Time........
