Livinshallow
Thread starter- Joined
- Apr 16, 2006
- 26
I have a mrcury 40 hp 2003 with a two wire trim motor. The trim has always worked flawlessly and suddenly while on the trailer it stopped working. The solenoids are clicking and I have 12 volts coming to the motor while trim switch is pressed. The motor does nothing. I am guessing a bad ground possibly, although I have checked most of them and have cleaned and reattached if needed. If I run a hot lead to the blue or green wire directly will the motor run or does it have to be grounded.Thanks!
