turbinedoctor
Thread starter- Joined
- Sep 7, 2009
- 225
I have read http://forums.iboats.com/showthread.php?t=168855 and also have the manual. I have no problem going through the steps but my timing starts off at 5 degree ATC and when I go to adjust it, after I move past a certian point my spark drops out. I am using an inductive timing light. My trigger checks out ok, wiring is double checked. What would cause it to loose spark after coming slightly off on primary pick up? Is the some relationship between the stator position and the trigger. I am sure I have the stator back in the same position.
Forgot to mention, this is the first cranks after completing a rebuild and trying to set timing.
Durwood
Durwood
