jay_merrill
- Joined
- Dec 5, 2007
- 5,653
Re: 1967 Evinrude 6hp drive shaft reinsertion problems
Don't waste your time trying to figure out if it "goes up in there" - if the motor is reassembled properly, it does. You should also not waste your time wondering if the pin is necessary - it is. The point of the seal assembly, including the pin, is to keep water/moisture out of the powerhead. I have a frozen 6hp powerhead sitting in my shop right now - the victim of a missing seal assembly.
I just finished a water pump job on a 6hp of that vintage, the night before last. I've done a bunch of them and find the process to be pretty easy, if you do it correctly. The trick to lining the pin up with the slot in the upper end of the midsection, is to put the motor in gear and once the top of the drive shaft is in place, turn the prop (plug wires off and pulled away from he plugs, please!) so that the shaft turns clockwise, as viewed from the top. Do not turn counterclockwise even a little - if you do, the impeller blades will try to reverse or will reverse! Do this slowly, a bit at a time and try pushing the gear box up each time you stop. If you miss the slot, keep going clockwise, until you are properly lined up.
Like most repair jobs, this process is just a matter of learning the proper way to do things. Once you do, its not hard.
I have been debating to myself weather of not that upper pin actually does anything.
if you think about, the pin will force the Seal spring Washer to spin, along with the spring, lower seal, upper seal, Drive shaft to c'case washer & gasket. probably not good.
I dont think that the pin even goes up in there. I'll test my theory out in the morning.
