Shift Switch problems
PRdiver
Please let me know if someone knows why the shift switch of a Johnson 225 HP 1998 is getting burned. I replaced it twice, but I suspect there is something causing the switch to burn.
I hope you can help me.
Thanks in advance,
Joe Reeves
Re: Shift Switch problems
The only thing that will cause that switch to burn is if voltage is being applied to it. Disconnect it and trouble shoot the wiring with a volt meter.
