RLT III
Thread starter- Joined
- Jan 27, 2010
- 180
Stator 5,400&148
rectifier failed showed cont backwards then described in book(batt charges
stator alt test 1.5 ohm& no cont
trigger test 1,400
Mercury switch good
had trouble understanding high tension lead and figured tower was coil pack
so i tested cont on each coil was good
Then grounded to motor and tested coil terminals
this is what i found on the DCA reading (old meter)
#1=0
#2=1.8
#3=1480
so is it bad and is that why I'm having power loss at wot and if the rectifier is bad is that why too my batt still charges
Please help
trigger test 1,400
Mercury switch good
#1=0
#2=1.8
#3=1480
Please help
