Some of you have helped me through my first rebuild. The rebuild is done and I have finished with the break in. I thought that the hard to start and loading at idle would go away as my mix got back to ratio got back to normal, but that hasn't happened. I am thinking the problem is improper float adjustment, primary timing or my not changing all the needles and seats in the carbs.
I plan to pull the carbs back off Saturday and install new needles and seats, also check the float adjustments, and install new plugs. I have already removed the stabilization mod. and have WOT timing set at 23 BTDC. The Selco book I have said to set the primary timing at 11 ATDC. Is that correct? I have checked the entire ignition system and everything checks good.
The motor try's to start when cold but wont stay running. I have to push the throttle to about 3/4 and it will clear out, then I pull back to around 1500 RPM and hit the choke 3 or 4 times. I can then go to idle which is at around 850 RPM. If I shut it down even after warm and it sits for a while is becomes hard to start again but not as hard as when completely cold.
Is that primary timing right at 11 ATDC and is there anything else I should check before I take it back to the lake?
