distributor question.
gtownky
how much is a distributor fo an older chryser 140hp motor? I think mine is hanging up when I give it more gas and is putting things in a bind as it trys to advance. Not 100% that is the problem but it appears that way. Is this a common issue? Thanks
gtownky
Re: distributor question.
Tryed to pm you but cant for some reason.
Frank Acampora
Third try: It is common to have the distributor hang up if the drive belt is too tight. I sent two long posts describing it but it keeps cutting me out. Too tight will cause the distributor to bind and shift hang-up. too loose and timing will shift while running.
Frank Acampora
So now I will try a couple of lines at a time. To adjust, loosen the to two bolts just enough to let the distributor move. Push it in (front bolt is in a slot) then pull out firmly. Snug the front bolt and test: A .010 feeler gauge held like you are pointing a finger should deflect the belt 1/8 to 3/16 inch at the center before bending. You may need to try a time or two before getting it correct. Then fully tighten the mounting bolts and re-check. Sometimes the distributor mounts at a very slight angle and the belt will tighten when you fully snug the bolts.
With age, the grease inside hardens. To clean, remove the top pulley. Remove the large circlip holding the dist. into the mount and remove the dist. clean the bronze bushing and clean the aluminum dist. body. Lightly re-grease and assemble. Pump a few shots of grease into the zerk fitting.
Before setting anything, set the flywheel to top dead center. That way if the belt moves or you remove the pulley, it can be reset correctly. With the flywheel at TDC, set the curve in the top of the pulley to match the flywheel circumference curve and have the straight line pointing directly at the flywheel. Do this with the dist. at the approximate correct setting because the pulley will move about one tooth as the dist. is moved in and out.
Frank Acampora
Re-read all the posts as I did numerous edits to fully reply.
gtownky
Thanks Frank, I will try this.
