I have this problem with my OceanRunner 200 for several seasons now. Runs great except when I've been running it for a while shut it off and then try to start it.
It will start right up and stall once it comes off the quick start. I'll start again and it will stall again once it comes off the quick start. I'll do this three or four time untill it idles, it will then run perfect untill I shut it off again at which I'll have to run through the whole process again.
The idle setting is right on, I've checked all the hoses for air leaks and have found nothing. Checked the timing, changed the plugs. I'm wondering if maybe it's idle mixture, not sure what else it can be.
Any help would be greatly appreciated,
Victor.
Victor.
