synk and link question
jcdsog
do i need to do this on my motor. its the 84 8hp. i read the top secret file and a few others about it but i'm not sure how to do it on my motor.
Re: synk and link question
Link & sync synchronizes throttle opening with ignition timing and yes it is required on your engine -- but only if need such as if components have been replaced, linkages messed with by previous owners, or if you are experiencing issues that require a thorough inspection and adjustment of the carb/ignition system linkages. You need a factory service manual for this procedure and you need to follow it to the letter from beginning to end. It is far too detailed to go into here.
jcdsog
wow. well thanks. i just took my motor apart so hopefully i will just put it back together exactly how it came apart and it will be fine. i tried not to adjust or move anything if at all possible.
