tilt trim ? on 86 175 johnson
bgooden
i have a 86 175 johnson and am having trouble getting the tilt trim to work. all i hear is a click at the trim motor . could the motor be stuck ( it has been sitting awhile ). is there a way to check the motor without removing it? how can i check the hydro setup?
mitchell6
Re: tilt trim ? on 86 175 johnson
might need a new silonod switch or check the connections at the battery
bgooden
I've tried jumping the motor straight from the battery and still nothing!!
bgooden
took the motor off and it works fine, the pump on the other hand is shot. so i guess i need to go get a new unit. thanks for the input.
bignefan
ouch that'll cost ya
bgooden
i got lucky and can get a complete motor minus the lower unit for 350.00 or a guy in Atlantic Beach ,NC can get me a good used unit for 250.00 guarenteed for a year. I think i'm going with the complete motor.
bignefan
The o-ring kit for the trim is $40.00, I made a tool to remove the end caps off the pistons it wasn't to hard.It was harder getin it off the motor. I haven't found a kit for the tilt piston, but that wasn't the problem with my unit. Sounds like you found a good deal anyways
