Set no 1 piston to top dead center on the compression stroke and put the rotor button pointing to no 1 spark plug lead on the dizzy cap, turn it back about 20mm as it has a helical gear at the bottom of the dizzy, once its fully installed make sure the distributor rotor is pointing to no 1 spark plug lead on the dizzy cap, also ensure you can turn the distributor comfortably either way to adjust timing. should start now
