25thmustang
Thread starter- Joined
- Mar 20, 2008
- 1,849
I'm not sure many people will have the answer I'm looking for, but here goes.
I ripped the old nasty carpet, wall covering and healiner out of my boat, and am left with the epoxied plywood. I will be hitting this with a combination of wire wheel and flap wheel to remove any and all signs of glue, adhesive or left over material. I should be left with just epoxied wood. My questions comes in with regards to the sruface I will have. Although it levels off alright after it gets hit with the flap/wire wheels it is still "wavy" or "bumpy" and not perfectly smooth. I do know the carpet should lay down over and hide this, but knowing I have it to this point, I want to put a coat of something down and level it as best I can.
I found some floor leveling products at the local HD and Lowes which peak my interest. Number one, for the fact that it will withstand abuse. Number two for the fact that it shouldn't see a ton of water, as it will be below decks, and the boat should be water tight. Number three, it's local and easy to get. This is a big one for me, as I hate sitting and waiting for products to arrive. I like being able to make a quick stop and have what I need. Working with weekday nights, doesn't give me all the time in the world and any time saving is huge.
So what do you guys think? Has anyone used a product like this? Should I not even bother where the carpet will go? Should I only use it where the laminate type flooring will be (this needs to be 100% smooth BTW)? Is there a different product I should look into?
Thanks in advance.
Thanks in advance.
