Paint Question
1506cmo18
Re: Paint Question
If you are dead set on rolling paint on..I suggest you look through these threads and see how they did it, and how it came out..
http://forums.iboats.com/showthread.php?t=357767
This one is amazing too..but he sprayed it on.
http://forums.iboats.com/showthread.php?t=364284
Is there something wrong with rolling paint on?
I still think it would be easier to start with a fresh cote of paint then it would be to sand and buff an old one out. You gotta remember that the paint has been on the boat for probably 30 some years...I'm sure ti could be done, but with a lot more time
MTribe08
Re: Paint Question
Nope, not at all. Thats why I showed you those threads...they are both excellent examples of rolled on paint. And you may be right about putting a fresh coat of paint on, obvious if you want to change the color.
Good luck.
1506cmo18
Re: Paint Question
Good luck.
Thank you for all the help everyone!...I'm 99.9% sure I'm going to put a couple of layer of Brightside Polyurethane Fire Red 4248..Anyone with experience with this paint?
QC
Re: Paint Question
I've used Brightside and it is great, but I just want to clarify one thing. Gelcoat is not paint, and it is waaaaaay more durable. That's why most of us are recommending sanding out if you can. There are reasons not to, and not liking the color is one of those. But very few of us would paint over gelcoat if it will clean up . . . ;)
1506cmo18
Re: Paint Question
Reason I want to paint are:
1) not a fan of the color
2) 30-40 years old
3) trailer boat only used in fresh water
4) A lot more work getting the original color back
Thanks for you opinion on the paint!
1506cmo18
Re: Paint Question
Plus today I sanded it down in a small place and took some mother fine cut wax and tried buffing...A small change but not much...
I understand the gel coat is a lot stronger, but a painted boat should last a few years of fresh water riding right? Or are you saying that its going to need to be repainted every season?
QC
Re: Paint Question
Agree with ezmobee, but just wanted to confirm you understood the difference between gelcoat and paint. All good.
1506cmo18
Re: Paint Question
I went over the boat to day with a sander and used 1000 grit....It didn't rough it up as well as I imagined....How much sanding is needed?
Should I start with a 300-400 and work my way up? or am I only sanding to take away the shine?
voyager al
Re: Paint Question
You can get by with just scotch-brite pad and a good cleaner like Purple power. I painted my old station wagon that way. its 24 years old. Not worth a 1500 dollar paintjob. I am now ready to paint my 1964 boat with foam roller. It will be good enuf for a 800 dollar boat. There wasnt enuf gelcoat to buff. i could see thru it, to the glass.
1506cmo18
Re: Paint Question
So the sanding is just to clean the surface and ruff it up abit
QC
Re: Paint Question
Most single part paints recommend 320 - 400 prep . . . Between coats as well.
osborn159
Re: Paint Question
follow the instruction on the can, choose whatever paint you like, generally sand to knock the gloss off the surface, to be safe read the instructions on the paint can
1506cmo18
Re: Paint Question
A little update!
finished painting this weekend, still have to do little touch up and remove the tape....overall looks excellent very impressed how the paint job turned out
let me know what you guys think!
Thanks to everyone who chirped in
Cmo
