texaslakesideman
Thread starter- Joined
- Mar 23, 2010
- 16
My current drive system is 2000 GM 5.0l with a Volvo Penta SX-M out drive. I found and have purchased a modified 79 302. This 302 now puts out 365 horses and can run up to 8000 rpm. The 302 has been pulled after 3 hours of use from a Mercruiser Gen I out drive. The bolts on parts are still on the tail of the engine from the Gen I. Now I need to figure out what parts I need to connect this engine into my existing 2000 SX-M. What will I need to replace on the replacement engine to match my current out drive? I have not picked up the replacement engine yet. I will do so in about 2 weeks. I am in Texas and have to go to Florida for the engine. Just want to be ready with the needed parts.
The replacement engine:
THIS IS A COMPLETELY REBUILD 302 FORD 350+ HP . BLOCK IS BORE .030 OVER, IT HAS BRAND NEW SPEED PRO SEALED POWER 10:1 COMPRESSION PISTONS. BRAND NEW MOLY CHROME PISTONS RINGS,NEW BEARINGS,EVERY THING ON THE BLOCK IS NEW , ETC. THE HEADS ARE THE HI-PERFORMANCE 210cc 2.02/1.60 -20 DEGREE VALVE ANGLE- 60cc COMBUSTION CHAMBER , WITH STUD ROLLER ALUMINUM ROCKER ARMS, STREET 3 ANGLE VALVE JOB , THEY ARE MACHINE TO USE CHEVY 2.02"/1.600"/ .100" VALVES, THE HEADS BY THEY SELF AT WORTH WELL OVER $1000.00 . THE INTAKE MANIFOLD IS AN EDELBROCK ALUMINUM PERFORMANCE RPM , THE CARBURATOR IS A BRAND NEW HOLLEY 600 VACUUM SECONDARY ELECTRIC CHOKE WITH A 1" SPACER. THE CAMSHAFT IS A ERSO RV 10H 280 DEGREE INT AND EXHAUST 448 DURATION, BRAND NEW HI-TORQUE STARTER,HI-VOLUME OIL PUMP,ETC. TO MANY THINGS TO LIST. THIS MOTOR COMES WITH FRONT MOTOR MOUNTS and REAR MOTOR MOUNTS INCLUDING THE BELL HOUSING.
