going from 8" tires to 12" tires
NYGiants
would i be able to go from 8" tires on my small 14" trailer to 12" without changing the hub? As in does the 12" wheel have the same bolt pattern
shuswap119
Re: going from 8" tires to 12" tires
Hi NY,
Yes, you can go from an 8" to a 12" wheel as long as you have fender clearance to accommodate the taller tire that is used on the 12" wheel. Both wheels will be available with the same bolt pattern.
Regards,
NYGiants
Thanks shus.
just wanted to make sure before i went out and bought bigger wheels
Tom P
As mentioned, the answer is yes. But, realize that you?re going to need more water to launch and retrieve. If NYGiants boats by Giant Stadium in the Hackensack River, having 8? tires is a blessing. The ramp at Laural Hill park and the other ramps end just beyond the low tide mark. 4? less or water makes a difference. I changed from 12? to 8? tires.
Tom
AKA
Tom?s Toy
izoomie
Why are you trying to change the size of the tire? Is there another issue you are trying to solve?
