dish
Thread starter- Joined
- Aug 22, 2008
- 151
Having a lot of dramas with vRO on 1997 150 ocean pro.It justy wont pump fuel.Pumps plenty of oil into carbs.Pumps fuel if i squeeze bulb or have fuel above pump.Checked everything,air leak,blockage,compression,antisyphon,pulse fitting.No air bulbbles going to pump with clear hose connected.The bulb stays primed it just wont pick up the fuel.Has anyone had any success with the rebuild kit for the fuel side of VRO,and if the vapour pump is not working would that stop the pump from picking up fuel?Not reaaly sure what the vapour pump does except give you a fuel restriction warning through the sensor.Some one must have an idea????
