stephentyler20
Thread starter- Joined
- Apr 13, 2008
- 117
Sorry for the low quality pic, I can take higher res if necessary.
This is my dash in its current state. I removed a black plastic/fiberglass piece that covered this whole thing, and which contained my gauges, buttons, etc. (pic of that on the bottom). Underneath was semi-finished gelcoat, with the gaping holes as you can see.
My goal is to "patch" everything up so I have a nice, flat surface, into which I can drill my new Teleflex gauges (circular gauges).
What you're looking at here: the top (forward) part is roughly 3/4" plywood covered with fiberglass. The face (aft) part, i.e. the part of the dash you look at, is fiberglass only (i.e. not plywood cored).
So what's the best way to create a flat surface in those areas? Should I somehow drill in plywood, then glass it over? And if so, how would I do that specifically? Should I just use mat fiberglass and poly resin? My thinking is if I can get the whole thing flush, I can then grind/sand everything down and regelcoat the entire thing for completion. I'd also like to close up the lower left hole, which originally had the ignition keyhole and a LED board. I'm just going to flush mount the ignition switch there.
Any other tips welcome!
http://i78.photobucket.com/albums/j98/stephentyler20/1988 210 Classic/boatdash.jpg
The original/stock setup (for the record, I'm replacing this whole thing so that I have nice new gauges that work, and a more "marine" feel).
http://i78.photobucket.com/albums/j98/stephentyler20/1988 210 Classic/SANY0162.jpg
