Over heated Jeep
saildan
Re: Over heated Jeep
I used my 1999 Jeep Cherokee to trailer today for the 1st time with down the NY Through-way about 50 miles. I was pulling a single axle trailer, with a 3,500 lb payload. On flat land I didn't have any problem. But on uphills, the Jeep over heated.
Tom,
I had a '99 XJ, 6 cyl, factory HD radiator, used to tow a boat and also experienced something similar.
For no apparent reason, after hauling across town or miles down the highway, the temp gauge would start to spike. Hills may have been a trigger, but it could also only have been just a slight change in grade.
I investigated everything everybody has discussed so far, even to the point of scientifically measuring waterpump output volume/pressure, radiator flow, and flow through the block.
Drove me nuts for months, more than a couple of times causing me to sit on the shoulder letting the engine cool.
Finally, an old school mechanic I know suggested I "burp" the cooling system. He said some cooling system designs have a high spot where air can get trapped and temporarily impeed flow. That the condition is inconsistant, but usually appears after cooling system maintenance.
We raised the Jeep's front on drive-up stands and warmed it up as near operating temp as possible with the radiator cap off. Then we shut it down, let it cool back to ambient, topped it up through the radiator with 50/50, and closed the system back up.
Back down on the level, we pulled most of the backup anti-freeze out of the reservoir anticipating some overflow and fired up the engine.
At operating temp the reservoir rose a normal amount, upon cooling it pulled the same amount back into the system. With that, I filled the reservoir to its normal cold level...
That was at 60k, I drove that Jeep another 100k and never had another overheat.
basshunter62
a simple way to check if the rad. is clogged is. run engine untill it gets up to operating Then turn off ignition if you have an electric fan make shure it dosent turn on without key on first. (some vehiclesfans will turn on automaticly.without the key turned on. reach in from the back and feel the radiator fins. thay all should feel about the same temp. if you feel cooler spots that will indicate a cloged radiator good luck!! (just my 2 cents)
sprintst
Tom,
I had the same issue where the system needed to be burped. It was due to the alum intake not being torqued correctly to the cast iron heads. They expand and contract at different rates.
I swapped out the rad after a flush, tightened up the intake bolts to spec, swapped hoses and thermostat and drove another 100,000 with no issues.
The flush kit may even have a T fitting to put inline into your heater hose. You run it back up to temp and just slightly open the cap on the t fitting until the coolant is running out and then snug it back up.
You'll be surprised of the color of the water that comes out during the flush. Peace of mind knowing you got all that junk out before the new rad went in.
Tom P
Just an update . . . .
Radiator has been flushed. I'm having the largest radiator put in that will fit this Tuesday. I'll be towing on Friday, 30 min of highway driving and 30 min of back road hills. That should prove to be the acid test.
Tom
smokeonthewater
good luck tom... hopefully this will fix you up and we won't need to dive into it any deeper.
Tom P
Well, I had the new radiator install Tuesday and I towed today. 10 min of local driving, 30 min of highway driving (50-60 mph), 30 min of rural, up the hilll, down the hill (30-40 mph at 2k/3k rpm). The temp never hit 210 deg. All is well. Thanks all for your help.
Another trailering problem solved by iBoats,
Tom
