Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I just got a 115 and it will idle part of the time, and then not, it runs fine high rpm, just rough Idle. Also on muffs water is visible at the low center of engine near the pee hose. Suggestions Thanks
As to the water you are observing, take the hood off and have a look see.
As to the other your description points to a fuel issue. I suggest that you spend some time reading in the FAQ section. There are a bunch of things for you to do to a new to you engine.
