Piston Failure
CLAYC
2.5L 200 EFI, less than 20 hrs on engine since rebuild, WSM Pistons. #1 piston failure. Looks like bottom ring spun on piston allowing ring to hang on exhaust port, good-bye top of piston. The ring pin looks broken or pushed into piston. Either way, it allowed for failure.
Is this a problem with WSM Pistons or is this common. Will WSM warranty the failed part?
I'm getting tired of tearing down the same engine; gaskets, rod bolts, and rings are not given away.
Faztbullet
Re: Piston Failure
Hey Clay ya bought them from me so send it back and I will get MFG to replace if defective, pm me!!! As pin turning never had any problems with WSM stuff.
CLAYC
Re: Piston Failure
Thanks, I will pm you right now....
